By Noobie
#79368 Hi all,
I have got a program which is for a nodemcu esp 8266, gas sensor, and ifttt (email).
I have changed the gas sensor for a pir sensor in the program. The first problem i have is i received over 100 emails in about 3 mins. Emails were still coming through after i disconnected the power to the nodemcu. "Is this a problem with the program or with the setup of ifttt?".
The second problem i have is.... I want to add a led light to the program but don't know where to add the code for the led into the program. I want the led light to be activated for 3-5 secs when the pir is activated. This only needs to happen once. I want to be notified of movement only the first time the pir is activated. Should I program the pir to power off after one activation?
Sorry for the long post, i have so many questions.
Thank you
Noobie :)
By schufti
#79382 and what are we expected to do?
our magic crystal ball is out of service ....
If you don't show us what you have so far the only correct answer is "maybe".
By Noobie
#79389
schufti wrote:and what are we expected to do?
Lol.... I can lend you my crystal ball :D
My apologies mate. Its my first time on a forum. I will chuck it up in 20
By Noobie
#79392 ok i am going to try and upload the code i have as an attachment. please let me know if it doesn't work or if there is a better way to post it.
Thanks Noobie
