By archer1035
#81931 Hello,
I'm a beginner to making HTTP calls on devices and I'm trying to implement the following API on the ESP8266 using C on the Arduino IDE. The device I am using is the Adafruit Huzzah board.
The code I want to implement is as follows:
curl -X POST \ https://<host>:<port>/api/v1/provision/devices/register \
-H 'Authorization: Bearer <JWT_TOKEN>' \
-H 'Content-Type: application/json' \
-H 'X-Device-ID: TEM-1235686759' \
-d '{ "type": "TEM",
"serialNumber": "234455",
"uuid":"1235686759" }'
I am used to working with C and C++ so I'm a bit unfamiliar in how I would make this work on the ESP8266. Some guidance or personal experience with similar challenges would be much appreciated!
Thank you!
