By schufti
#87033
so I will avoid long loops? It makes sense, but loses the elegance.
quite contrary as it shows your understanding for state machines.
For µC's a program that gets cought in a empty loop is allways a threat for "dead loops".
The concept of constantly looping and reacting on (change of) signals (state machine) is the way to go as it allows for constant monitoring of a healthy state.
It can get so atomic that on one step in the loop you check the opto and just set a "signal", in another step where you e.g. advance a stepper one step cw/ccw you do this depending on this "signal".
By MeMagic
#87131
ucp.php
OK, so I have removed all my delays and skip everything until the "moment is right" instead.
Still, can't make it work as I'm exepcting. Please, somebody take a look at the code and tell me what I'm doing wrong this time.
Code: Select allbyte FwdPin = 12;
byte BkwPin = 13;
byte OpcPin = 14;
int TargetTimer = 0;
byte System_NonCalibrated = 0;
byte System_CalibrationStarted = 1;
byte System_InitExtremeFound = 2;
byte System_FindFwdExtreme = 3;
byte System_ForwExtremeFound = 4;
byte System_FindBkwExtreme = 5;
byte System_BckwExtremeFound = 6;
byte System_AvgCcleTimeFound = 7;
byte System_Calibrated = 8;
byte System_State = 0;
byte System_PrevState = -1;
byte System_StartFwdMtn = -1;
byte System_EndFwdMtn = -1;
byte System_StartBkwMtn = -1;
byte System_EndBkwMtn = -1;
byte Motor_State = 0;
byte Motor_StopSignal = LOW;
byte Motor_RunSignal = HIGH;
byte Motor_RunForwd = 2;
byte Motor_RunBackw = 3;
int Motor_AvgCcleTime = 0;
byte OC_State = 0;
byte OC_Prev = -1;
byte OC_Covered = LOW;
byte OC_NonCovered = HIGH;
byte OC_CoverCount = 0;
  pinMode(OpcPin, INPUT);
  pinMode(FwdPin, OUTPUT);
  pinMode(BkwPin, OUTPUT);
  Serial.println("   Let's ROCK!");
void Motor_Stop()
  digitalWrite(FwdPin, Motor_StopSignal);
  digitalWrite(BkwPin, Motor_StopSignal);
  Motor_State = Motor_StopSignal;
void Motor_StartForward()
  Motor_Stop();
  digitalWrite(FwdPin, Motor_RunSignal);
  Motor_State = Motor_RunForwd;
void Motor_StartBackward()
  Motor_Stop();
  digitalWrite(BkwPin, Motor_RunSignal);
  Motor_State = Motor_RunBackw;
void System_Calibration()
  switch (System_State) {
    case 0:
      Motor_StartBackward();
      System_State = System_CalibrationStarted;
      System_StartFwdMtn = 0;
      System_StartBkwMtn = 0;
      System_EndFwdMtn = 0;
      System_EndBkwMtn = 0;
      break;
    case 1:
      if (OC_State == OC_Covered) {
        Motor_Stop();
        System_State = System_InitExtremeFound;
        TargetTimer = millis() + 2000;
      break;
    case 2:
      Motor_StartForward();
      System_StartFwdMtn = millis();
      System_State = System_FindFwdExtreme;
      break;
    case 3:
        System_EndFwdMtn = millis();
        Motor_Stop();
        System_State = System_ForwExtremeFound;
      break;
    case 4:
      System_StartBkwMtn = millis();
      System_State = System_FindBkwExtreme;
      break;
    case 5:
        System_EndBkwMtn = millis();
        Motor_Stop();
        System_State = System_BckwExtremeFound;
      Break;
    case 6:
      Motor_AvgCcleTime = (System_EndFwdMtn - System_StartFwdMtn + System_EndBkwMtn - System_StartBkwMtn) / 2;
      TargetTimer = millis() + int(Motor_AvgCcleTime / 4);
      Motor_StartForward();  //   turn it to 45 degrees.
      System_State = System_AvgCcleTimeFound;
      break;
    case 7:
      System_State = System_Calibrated;
      break;
  OC_State = digitalRead(OpcPin);
  if (System_State < 0 or System_State > 8) System_State = System_NonCalibrated;
  if (OC_Prev != OC_State) {
      Serial.println("Opto interrupter covered.");
      if (System_State == System_Calibrated) OC_CoverCount++;
      if (OC_CoverCount > 5) {
//   send it to start over if I cover the OI for five times while it is calibrated. Just for testing
        OC_CoverCount = 0;
        if (System_State == System_Calibrated) System_State = System_NonCalibrated;
    else {
      Serial.println("Opto interrupter not covered");
    OC_Prev = OC_State;
  if (TargetTimer < millis()) if (System_State != System_Calibrated) {
    System_Calibration();
  if (System_State == System_Calibrated and Motor_AvgCcleTime <= 0) {
  yield();   //   almost sure, it has nothing to do with my code now.
In output I have this:
Code: Select allCurrent system state -
Opto interrupter not covered.
System not calibrated. Starting initial rotation backward.
Current system state - 1
Initial extreme found. What next?
Current system state - 2
Started measurement rotation forward. Start forward time = 110
Current system state - 3
Measurement rotation forward stopped. End forward time = 179
Current system state - 4
Started measurement rotation backward. Start backward time = 132
Current system state - 5
Measurement rotation backward stopped. End backward time = 74
Current system state - 6
Average circle time calculated - 5 millisecs.
Current system state - 7
System calibrated?
Current system state - 8
What's going on? Why a later millis() returns a smaller value that an earlier one?
By MeMagic
#87134
MeMagic wrote:OK, so I have removed all my delays and skip everything until the "moment is right" instead.
So, I've found an error in my previous code - I used byte values for storing millis() output. After correction time vars are showing ascendant values.
Here is the new code, this time I have left the code for debug output, so it is clear what is output and when:
byte BkwPin = 13;
byte OpcPin = 14;
unsigned long TargetTimer = 0;
byte OC_State = 0;
byte OC_Prev = -1;
unsigned long System_StartFwdMtn = -1;
unsigned long System_EndFwdMtn = -1;
unsigned long System_StartBkwMtn = -1;
unsigned long System_EndBkwMtn = -1;
unsigned long Motor_AvgCcleTime = 0;
bool debug = true;
void debug_print(char str1[], unsigned long str2, char str3[]) {
  if (!debug) return;
  if (str1 != "") Serial.print(str1);
  if (str2 != 0) Serial.print(str2);
  if (str3 != "") Serial.print(str3);
void Motor_Stop()
  Motor_Stop();
  Motor_Stop();
    case 0:
      debug_print("System not calibrated. Starting initial rotation backward.", 0, "");
      break;
    case 1:
        Motor_Stop();
        debug_print("Initial extreme found. What next?", 0, "");
      break;
    case 2:
      TargetTimer = millis() + 400;
      debug_print("Started measurement rotation forward. Start forward time = ", System_StartFwdMtn, "");
      break;
    case 3:
        Motor_Stop();
        debug_print("Measurement rotation forward stopped. End forward time = ", System_EndFwdMtn, "");
      break;
    case 4:
      debug_print("Started measurement rotation backward. Start backward time = ", System_StartBkwMtn, "");
      break;
    case 5:
        Motor_Stop();
        debug_print("Measurement rotation backward stopped. End backward time = ", System_EndBkwMtn, "");
      break;
    case 6:
      debug_print("Average circle time calculated - ", Motor_AvgCcleTime, " millisecs.");
      break;
    case 7:
      debug_print("System calibrated?", 0, "");
      break;
  if (System_State != System_PrevState) {
      debug_print("Current system state - ", System_State, "");
      System_PrevState = System_State;
      debug_print("Opto interrupter covered. Time: ", millis(), "");
        OC_CoverCount = 0;
    else {
      debug_print("Opto interrupter not covered. Time: ", millis(), "");
    OC_Prev = OC_State;
  if (TargetTimer < millis()) if (System_State < System_Calibrated) {
    debug_print("Average circle time corrupted, going to run calibration. Average circle: ", Motor_AvgCcleTime, ".");
  yield();
And here is the output:
Code: Select all   Let's ROCK!
Opto interrupter not covered. Time: 61
Opto interrupter covered. Time: 4927
Opto interrupter not covered. Time: 4927
Opto interrupter covered. Time: 4928
Started measurement rotation forward. Start forward time = 6928
Measurement rotation forward stopped. End forward time = 7329
Opto interrupter not covered. Time: 7678
Started measurement rotation backward. Start backward time = 9330
Opto interrupter covered. Time: 11689
Measurement rotation backward stopped. End backward time = 11689
Average circle time calculated - 1380 millisecs.
System calibrated?
Opto interrupter not covered. Time: 17653
Opto interrupter covered. Time: 20302
Opto interrupter not covered. Time: 20302
Opto interrupter not covered. Time: 22919
As one can see from the output, there are a couple of same values for time - it happened when I was removing the handmade flag from the Opto Interrupter (Opto Isolator?). I don't know why it reacts so sharp when placing and removing the flag in/from the Opto Interrupter's opening. Is the ESP-12 defective?
