By Esperks
#88773 I'm trying to use WLED and flashing works fine, but after startup I don't see any wifi network for WLED.
When I start the module, the leds turn amber so it seems that WLED is running.
If I load something else to the board I can see a wifi network.
I have tried two different boards, and have had the same issue with both. What should I do to make the wifi network visible? Thanks!
Edit: The boards are ESP-12-F and one that looks like this but has 4MB flash.
I have also tried a ESP32-pico-kit board, and there the WLED-AP is visible at first boot and I can even get it to connect to my wifi network. But after the first reboot, it's not connecting anymore.
