By straygrey
#89682 In an attempt to display output from DJRobots weather station on the internet I have the following code.
#include <SoftwareSerial.h>
 const char* ssid = "MySSID";
 const char* password ="MyPassword";
 unsigned long Secs = 0;
 bool newData = 0;
 bool err =1;
 char data[53];
 byte i = 0 ;
 byte x = 0 ;
 WiFiServer server(80);
SoftwareSerial swSer(D1, D2, false); //, 256);
 void setup()
     Serial.begin(115200);  // This is the baud rate for ESP's Serial at USB which can be viewed in Arduino IDE Serial monitor
     swSer.begin(9600);     // This is the baud rate for esps Software serial at pins D1 and D2 so it can communicate with arduino
     delay(10);
     Serial.println(ssid);
     WiFi.mode(WIFI_STA);
     WiFi.begin(ssid, password);
         Serial.print(".");
     Serial.println("");
     server.begin();
     Serial.println("Waiting for the IP Add...");
     delay(5000);
 void loop()
     if (swSer.available() > 0 )
         char Z = swSer.read();
         if(Z=='c')   // match first Character to check "validity"
             {        // and this letter 'c' is not stored in the array below
             newData=1;
             Secs=millis()/1000;
             for(i= 0; i< 52; )
                 data[i] = swSer.read();
                 i++;
                 data[i] = '\0';
             for(i=0; i<52;)
                 {                // serial print to arduino ide monitor via usb,all the chars stored in data array
                 Serial.print("char number: "); // and print char number the INDEX number starting from zero
                    // the actual first char is the Letter "Z' which is not stored
                 Serial.println(i);
                 Serial.println(data[i]);
                 i++;
            err=1;
  // setStatus();
   sendHtml();
   if(millis()/1000 -Secs > 30 )
       Serial.println("Resetting Arrays");
       Serial.println(Secs);
//   ResetArrays();
       Secs=millis()/1000;
int transCharToInt(char *_buffer,int _start,int _stop)                               //char to int)
    int _index;
    int result = 0;
    int num = _stop - _start + 1;
    int _temp[num];
    for (_index = _start;_index <= _stop;_index ++)
        _temp[_index - _start] = _buffer[_index] - '0';
        result = 10*result + _temp[_index - _start];
    return result;
int WindDirection()        //Wind Direction
    return transCharToInt(data,1,3);
float WindSpeedAverage()                                                             //air Speed (1 minute)
    float temp = 0.44704 * transCharToInt(data,5,7);
    return temp;
float WindSpeedMax()        //Max air speed (5 minutes)
    float temp = 0.44704 * transCharToInt(data,9,11);
    return temp;
float Temperature()        //Temperature ("C")
    float temp = (transCharToInt(data,13,15) - 32.00) * 5.00 / 9.00;
    return temp;
float RainfallOneHour()                                                              //Rainfall (1 hour)
    float temp = transCharToInt(data,17,19) * 25.40 * 0.01;
    return temp;
float RainfallOneDay()                                                               //Rainfall (24 hours)
    float temp = transCharToInt(data,21,23) * 25.40 * 0.01;
    return temp;
int Humidity()        //Humidity
    return transCharToInt(data,25,26);
float BarPressure()        //Barometric Pressure
    float temp = transCharToInt(data,28,32);
    return temp / 10.00;
void sendHtml()
    if (client)
        Serial.println("New client");
        boolean blank_line = true;
        while (client.connected())
            if (client.available())
                char c = client.read();
                if (c == '\n' && blank_line)
                    client.println("HTTP/1.1 200 OK");
                    client.println("Content-Type: text/html");
                    client.println("Connection: close");
                    client.println();
                    client.println("<!DOCTYPE HTML>");
                    client.println("<html><center>");
                    client.println("<head><meta http-equiv='refresh' content='5'/></head><body><h1>Esp8266 Serial to Wifi Weather Monitor Ver: 1.0</h1>");
                    client.println("Wind Direction: ");
                    client.println(WindDirection());
                    client.println("<br>");
                    client.println("Average Wind Speed (One Minute): ");
                    client.println(WindSpeedAverage());
                    client.println("m/s  <br>");
                    client.println("Max Wind Speed (Five Minutes): ");
                    client.println(WindSpeedMax());
                    client.println("Rain Fall (One Hour): ");
                    client.println(RainfallOneHour());
                    client.println("mm <br>");
                    client.println("Rain Fall (24 Hour): ");
                    client.println(RainfallOneDay());
                    client.println("Temperature: ");
                    client.println(Temperature());
                    client.println("C <br> ");
                    client.println("Humidity: ");
                    client.println(Humidity());
                    client.println("%  <br>");
                    client.println("Barometric Pressure: ");
                    client.println(BarPressure());
                    client.println("hPa <br>");
                    client.println("");
                    client.println("");
                    client.println("</center></body></html>");
                    break;
                if (c == '\n')
                    blank_line = true;
                else if (c != '\r')
                    blank_line = false;
        delay(1);
        client.stop();  // closing the client connection
        Serial.println("Client disconnected.");
It all seems to work perfectly well except it does not receive any data from the serial port.
Please tell me how I got this wrong.
