By Lipu
#92214 I want to make a home automation project with nodemcu 0.9(esp-12 module). But when i compile coming error, (i found this idea from a youtube channel named "saurabh lanje".) can any one help me please. Pls pls pls
Code: Select all
#define BLYNK_PRINT Serial
#include <WiFiClient.h>
#include <BlynkSimpleEsp8266.h>
BlynkTimer timer;
#define DEBUG_SW 1
// Pins for Fan Regulator Knob
#define s1  12 //D6
#define s2  13 //D7
#define s3  15 //D8
#define s4  16 //D0
// Pins for Switches
#define S5 9  //SD2
#define S6 10 //SD3
// Pins for Relay (Appliances Control)
#define R5 5  //D1
#define R6 4  //D2
// Pins for Relay (Fan Speed Control)
#define Speed1 0  //D3
#define Speed2 2  //D4
#define Speed4 14 //D5
// By default the mode is with_internet
int MODE = 0;
// You should get Auth Token in the Blynk App or in Gmail.
// Go to the Project Settings (nut icon).
char auth[] = "AUTH TOKEN";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "WIFI NAME";
char pass[] = "PASS";
bool speed1_flag = 1;
bool speed2_flag = 1;
bool speed3_flag = 1;
bool speed4_flag = 1;
bool speed0_flag = 1;
int switch_ON_Flag1_previous_I = 0;
int switch_ON_Flag2_previous_I = 0;
BLYNK_WRITE(V0)
  int fan_speed = param.asInt(); // assigning incoming value from pin V1 to a variable
  if (fan_speed == 0)
    speed0();
  if (fan_speed == 1)
    speed1();
  if (fan_speed == 2)
    speed2();
  if (fan_speed == 3)
    speed3();
  if (fan_speed == 4)
    speed4();
BLYNK_WRITE(V1)
  int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
  digitalWrite(R5, pinValue);
  // process received value
BLYNK_WRITE(V2)
  int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
  digitalWrite(R6, pinValue);
void setup()
  pinMode(s1, INPUT);
  pinMode(s2, INPUT);
  pinMode(s3, INPUT);
  pinMode(s4, INPUT);
  pinMode(S5, INPUT);
  pinMode(S6, INPUT);
  pinMode(R5, OUTPUT);
  pinMode(R6, OUTPUT);
  pinMode(Speed1, OUTPUT);
  pinMode(Speed2, OUTPUT);
  pinMode(Speed4, OUTPUT);
  Serial.begin(9600);
  WiFi.begin(ssid, pass);
  timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
  Blynk.config(auth);//, ssid, pass);
void loop()
  if (WiFi.status() != WL_CONNECTED)
    if (DEBUG_SW) Serial.println("Not Connected");
    if (DEBUG_SW) Serial.println(" Connected");
    Blynk.run();
  timer.run(); // Initiates SimpleTimer
  if (MODE == 0)
    with_internet();
    without_internet();
void with_internet()
  // FOR FAN
  if (digitalRead(s1) == HIGH && digitalRead(s2) == LOW && digitalRead(s3) == LOW && digitalRead(s4) == LOW && speed1_flag == 1)
    speed1();
    Blynk.virtualWrite(V0, 1);
    speed1_flag = 0;
    speed2_flag = 1;
    speed3_flag = 1;
    speed4_flag = 1;
    speed0_flag = 1;
  if (digitalRead(s1) == LOW && digitalRead(s2) == HIGH && digitalRead(s3) == LOW && digitalRead(s4) == LOW && speed2_flag == 1)
    speed2();
    Blynk.virtualWrite(V0, 2);
    speed1_flag = 1;
    speed2_flag = 0;
    speed3_flag = 1;
    speed4_flag = 1;
    speed0_flag = 1;
  if (digitalRead(s1) == LOW && digitalRead(s2) == LOW && digitalRead(s3) == HIGH && digitalRead(s4) == LOW && speed3_flag == 1)
    speed3();
    Blynk.virtualWrite(V0, 3);
    speed1_flag = 1;
    speed2_flag = 1;
    speed3_flag = 0;
    speed4_flag = 1;
    speed0_flag = 1;
  if (digitalRead(s1) == LOW && digitalRead(s2) == LOW && digitalRead(s3) == LOW && digitalRead(s4) == HIGH  && speed4_flag == 1)
    speed4();
    Blynk.virtualWrite(V0, 4);
    speed1_flag = 1;
    speed2_flag = 1;
    speed3_flag = 1;
    speed4_flag = 0;
    speed0_flag = 1;
  if (digitalRead(s1) == LOW && digitalRead(s2) == LOW && digitalRead(s3) == LOW && digitalRead(s4) == LOW  && speed0_flag == 1)
    speed0();
    Blynk.virtualWrite(V0, 0);
    speed1_flag = 1;
    speed2_flag = 1;
    speed3_flag = 1;
    speed4_flag = 1;
    speed0_flag = 0;
  // FOR SWITCH
  if (digitalRead(S5) == LOW)
    if (switch_ON_Flag1_previous_I == 0 )
      digitalWrite(R5, HIGH);
      if (DEBUG_SW) Serial.println("Relay1- ON");
      Blynk.virtualWrite(V1, 1);
      switch_ON_Flag1_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch1 -ON");
  if (digitalRead(S5) == HIGH )
    if (switch_ON_Flag1_previous_I == 1)
      digitalWrite(R5, LOW);
      if (DEBUG_SW) Serial.println("Relay1 OFF");
      Blynk.virtualWrite(V1, 0);
    if (DEBUG_SW)Serial.println("Switch1 OFF");
  if (digitalRead(S6) == LOW)
    if (switch_ON_Flag2_previous_I == 0 )
      digitalWrite(R6, HIGH);
      if (DEBUG_SW)  Serial.println("Relay2- ON");
      Blynk.virtualWrite(V2, 1);
      switch_ON_Flag2_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch2 -ON");
  if (digitalRead(S6) == HIGH )
    if (switch_ON_Flag2_previous_I == 1)
      digitalWrite(R6, LOW);
      if (DEBUG_SW) Serial.println("Relay2 OFF");
      Blynk.virtualWrite(V2, 0);
    if (DEBUG_SW)Serial.println("Switch2 OFF");
    //delay(200);
void without_internet()
  // FOR FAN
    speed1();
    speed1_flag = 0;
    speed2_flag = 1;
    speed3_flag = 1;
    speed4_flag = 1;
    speed0_flag = 1;
    speed2();
    speed1_flag = 1;
    speed2_flag = 0;
    speed3_flag = 1;
    speed4_flag = 1;
    speed0_flag = 1;
    speed3();
    speed1_flag = 1;
    speed2_flag = 1;
    speed3_flag = 0;
    speed4_flag = 1;
    speed0_flag = 1;
    speed4();
    speed1_flag = 1;
    speed2_flag = 1;
    speed3_flag = 1;
    speed4_flag = 0;
    speed0_flag = 1;
    speed0();
    speed1_flag = 1;
    speed2_flag = 1;
    speed3_flag = 1;
    speed4_flag = 1;
    speed0_flag = 0;
  // FOR SWITCH
  digitalWrite(R5, !digitalRead(S5));
  digitalWrite(R6, !digitalRead(S6));
// Fan Speed Control
void speed0()
  //All Relays Off - Fan at speed 0
  if (DEBUG_SW)Serial.println("SPEED 0");
  digitalWrite(Speed1, HIGH);
  digitalWrite(Speed2, HIGH);
  digitalWrite(Speed4, HIGH);
void speed1()
  //Speed1 Relay On - Fan at speed 1
  if (DEBUG_SW)Serial.println("SPEED 1");
  digitalWrite(Speed1, LOW);
void speed2()
  //Speed2 Relay On - Fan at speed 2
  if (DEBUG_SW)Serial.println("SPEED 2");
  digitalWrite(Speed2, LOW);
void speed3()
  //Speed1 & Speed2 Relays On - Fan at speed 3
  if (DEBUG_SW)Serial.println("SPEED 3");
void speed4()
  //Speed4 Relay On - Fan at speed 4
  if (DEBUG_SW)Serial.println("SPEED 4");
  digitalWrite(Speed4, HIGH); Blynk.virtualWrite(V4, 0);
  digitalWrite(Speed4, LOW);
//Check Blynk Connectivity every 3 seconds
void checkBlynk()
  bool isconnected = Blynk.connected();
  if (isconnected == false)
    MODE = 1;
  if (isconnected == true)
    MODE = 0;
By btidey
#92256 When seeking help I would suggest 2 things.
Tell us what error you get.
Try compiling a minimal sketch with no external libraries or dependencies to ensure you have the IDE set up correctly.
The multiple definitions of a function called BLYNK_WRITE look strange but I don't use BLYNK
Edit. Having looked a bit further these appear to be macros, but the main comment still applies. You need to say what error you get.
By Lipu
#92266
btidey wrote:When seeking help I would suggest 2 things.
Sorry bro, i am new in this field, i saw a video in youtube then trying to make this project. I dont know about coding. I am sending error report...
