If your sketch does not run, then the boot messages will give an error code.
Explore... Chat... Share...
bra1n wrote:Is the baud rate in your serial monitor set to 115200 (I suspect not)
rooppoorali wrote:As the previous answerer said, this type of garbage value appears in the serial monitor due to a baud rate mismatch. Kindly check that.
AcmeUK wrote:If you are getting gibberish whenever you push the button on the controller, THEN that will be messages from the boot ROM a 74880 baud.I don't see an option for a 74880 baud in the list?
