Moderator: eriksl
DEFINES = -D__ets__ -DICACHE_FLASH -DMEM_DEFAULT_USE_DRAM -DSPI_FLASH_SIZE_MAP=${SPI_SIZE_MAP} -DBUILD_ID="\"I${BUILD_DATE}\"" -DDEBUG_ON -DMQTT_DEBUG_ON
# compiler flags using during compilation of source files
CFLAGS = -std=gnu99 -flto -Wpointer-arith -Wundef -Werror -Wmissing-prototypes -Wstrict-prototypes -fno-builtin -fno-builtin-printf -fno-guess-branch-probability -freorder-blocks-and-partition -fno-cse-follow-jumps -ffunction-sections -fdata-sections -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -mno-serialize-volatile ${DEFINES}
CXXFLAGS = $(CFLAGS) -fno-rtti -fno-exceptions
# linker flags used to generate the main object file
LDFLAGS = $(CFLAGS) -Wl,-EL -Wl,-flto -Wl,-gc-sections -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--print-memory-usage -Wl,--cref -Wl,-Map=link.map #-Wl,-print-map
# linker script used for the above linker step
LD_SCRIPT = eagle.app.v6.ld
ifeq ($(ENABLE_GDB), 1)
CFLAGS += -Og -ggdb -DENABLE_GDB=1
MODULES += gdbstub
EXTRA_INCDIR += gdbstub
CFLAGS += -Os
endif
Do you need this one?
-Wl,--no-check-sections Regarding LTO: I've experienced most of the time IRAM usage decreases quite a bit, but:
- not always, sometime the usage even goes up
- it will mangle all symbols, if you're debugging or scanning memory usage, turn it off
- I'd recommend these flags using fto:
-flto=8 -flto-compression-level=0 -fuse-linker-plugin -ffat-lto-objects -flto-partition=max- no need to use
-Wl,-fltoWARNINGS := -Wall -Wextra -Werror \
-Wformat-overflow=2 -Wshift-overflow=2 -Wimplicit-fallthrough=5 \
-Wformat-signedness -Wformat-truncation=2 \
-Wstringop-overflow=4 -Wunused-const-variable=2 -Walloca \
-Warray-bounds=2 -Wswitch-bool -Wsizeof-array-argument \
-Wduplicated-branches -Wduplicated-cond -Wlto-type-mismatch -Wnull-dereference \
-Wdangling-else -Wno-incompatible-pointer-types \
-Wpacked -Wfloat-equal -Winit-self -Wmissing-include-dirs -Wstrict-overflow=2 \
-Wno-format -Wmissing-noreturn -Wbool-compare \
-Wsuggest-attribute=noreturn -Wsuggest-attribute=format -Wmissing-format-attribute \
-Wuninitialized -Wtrampolines -Wframe-larger-than=1024 \
-Wunsafe-loop-optimizations -Wshadow -Wpointer-arith -Wbad-function-cast \
-Wcast-qual -Wwrite-strings -Wsequence-point -Wlogical-op -Wlogical-not-parentheses \
-Wredundant-decls -Wvla -Wdisabled-optimization \
-Wunreachable-code -Wparentheses -Wdiscarded-array-qualifiers \
-Wmissing-prototypes -Wold-style-definition -Wold-style-declaration -Wmissing-declarations \
-Wcast-align -Winline \
-Wno-pointer-sign -Wno-unused-parameter -Wno-attributes \
-Wno-error=cast-qual -Wno-error=packed -Wno-error=unsafe-loop-optimizations
CFLAGS := -pipe -O3 -g -std=gnu11 -fdiagnostics-color=always \
-ffreestanding -fno-inline -mlongcalls -mno-serialize-volatile -mno-target-align \
-fno-math-errno -fno-printf-return-value \
-fno-tree-forwprop \
ifeq ($(USE_LTO),1)
CFLAGS += -flto=8 -flto-compression-level=0 -fuse-linker-plugin -ffat-lto-objects -flto-partition=max
endif
CFLAGS += -D__ets__ -DICACHE_FLASH -DLWIP_OPEN_SRC -DPBUF_RSV_FOR_WLAN -DEBUF_LWIP \
-DBOOT_BIG_FLASH=1 -DBOOT_RTC_ENABLED=1 \
-DIMAGE_TYPE=$(IMAGE) -DIMAGE_OTA=$(IMAGE_OTA) \
-DUSER_CONFIG_SECTOR=$(USER_CONFIG_SECTOR) -DUSER_CONFIG_OFFSET=$(USER_CONFIG_OFFSET) -DUSER_CONFIG_SIZE=$(USER_CONFIG_SIZE) \
-DRFCAL_OFFSET=$(RFCAL_OFFSET) -DRFCAL_SIZE=$(RFCAL_SIZE) \
-DPHYDATA_OFFSET=$(PHYDATA_OFFSET) -DPHYDATA_SIZE=$(PHYDATA_SIZE) \
-DSYSTEM_CONFIG_OFFSET=$(SYSTEM_CONFIG_OFFSET) -DSYSTEM_CONFIG_SIZE=$(SYSTEM_CONFIG_SIZE) \
-DOFFSET_OTA_IMG_0=$(OFFSET_OTA_IMG_0) -DOFFSET_OTA_IMG_1=$(OFFSET_OTA_IMG_1) -DSIZE_OTA_IMG=$(SIZE_OTA_IMG) \
-DOFFSET_IRAM_PLAIN=$(OFFSET_IRAM_PLAIN) -DSIZE_IRAM_PLAIN=$(SIZE_IRAM_PLAIN) \
-DOFFSET_IROM_PLAIN=$(OFFSET_IROM_PLAIN) -DSIZE_IROM_PLAIN=$(SIZE_IROM_PLAIN) \
-DSEQUENCER_FLASH_OFFSET=$(SEQUENCER_FLASH_OFFSET_0) -DSEQUENCER_FLASH_SIZE=$(SEQUENCER_FLASH_SIZE) \
-DSEQUENCER_FLASH_OFFSET_0=$(SEQUENCER_FLASH_OFFSET_0) -DSEQUENCER_FLASH_OFFSET_1=$(SEQUENCER_FLASH_OFFSET_1) \
-DOFFSET_OTA_BOOT=$(OFFSET_OTA_BOOT) -DSIZE_OTA_BOOT=$(SIZE_OTA_BOOT) \
-DOFFSET_OTA_RBOOT_CFG=$(OFFSET_OTA_RBOOT_CFG) -DSIZE_OTA_RBOOT_CFG=$(SIZE_OTA_RBOOT_CFG) \
-DFLASH_SIZE_SDK=$(FLASH_SIZE_SDK)
CINC := -I$(HAL)/include \
-I$(ESPOPENSDK)/xtensa-lx106-elf/xtensa-lx106-elf/include \
-I$(LWIP)/include -I$(LWIP)/include/lwip -I .
LDFLAGS := -L. -L$(ESPSDK)/lib -Wl,--size-opt -Wl,--print-memory-usage -Wl,--gc-sections -Wl,--cref -Wl,-Map=$(LINKMAP) -nostdlib -u call_user_start -Wl,-static
SDKLIBS := -lhal -lpp -lphy -lnet80211 -lwpa
LWIPLIBS := -l$(LIBLWIPAPP) -l$(LIBLWIPCORE) -l$(LIBLWIPNETIF)
STDLIBS := -lm -lgcc -lcrypto
