By FRANCISCOGIMENO1000
#84557 Hello friends, see if someone has happened to you.
In an esp8266 that is in STA mode I change it to AP mode and it works fine, but when I try to change it back to STA mode it doesn't connect to Wi-Fi.
I have to restart it and put it in STA mode and then it connects without problems.
The code is fine, because I use it when I restart it and it connects.
I tried a lot of things without result.
Greetings and thank you.
Fran
#84568 Yes, and nothing.
STA to AP mode is fine, but if I am in AP and pass it to STA it does not connect to Wi-Fi.
I've tried changing modes directly, turning off the chip's Wi-Fi, activating it and setting it to STA and nothing.
If I restart it works fine in any mode.
I have tried several ESPs and the same result.
I use the library version ESP8266 Arduino Core ESP 2.50.
