Moderator: eriksl
The only thing is that you don't have enough memory to hold them both open at the same time - for the most part this is not really a problem because you're often connecting to web sites and so you can do this one at a time.
As an example, I use Google Maps API via web calls, and I use IBMCloud as my MQTT platform. I have two CA certificate sets loaded in different areas of flash and have also found that Google needs a larger SSL buffer than IBM's MQTT, so for both I do:
espconn_secure_ca_enable(ESPCONN_CLIENT, ca_cert);
espconn_secure_set_size(ESPCONN_CLIENT, size);
before connecting.
For my information, what amount are we really talking about in practice?
