davydnorris wrote:The next step is to trace back from the ROM function to find out where it's being called from user land.
Using GDB can help here but it's problematic because the crash is random so you never know when it will happen, and adding the GDB stubs also changes timing but typically these sort of crashes can be timing sensitive
So, if norally deug method introduce a hard work, experiences might be more helpful. e.g. if someone else did some work before and then encountered this issue, it would be helful to summarry the possible causes.
