I'm working on a circuit that involves a load-cell + an HX711 chip that is used to measure the weight of something every pre-defined time, report it to a web server and go to sleep. I am currently using a power-bank connected by micro-USB to power the circuit. The power-bank lasts for 4 days when set to wake up every 1 minute and send the measurement over wifi only when there's a change in weight.
So I've been thinking about alternative ways to power this circuit and I was thinking of powering it using a 18650 Li-Ion battery (or batteries).
The HX-711 requires 5V to operate properly, so I understand I either need to use one 18650 battery with a boost converter or 2 batteries with a buck converter. I would like the circuit to be able to run without recharging for at least 2 weeks, and I am fine with having the deep sleep interval to be around 15 minutes (although ideally it would be less).
Is this possible using a single battery, or do I have to use two? What buck/boost converter would you recommend that is reliable and energy-efficient.
Thanks!
BTW: The specs of the power bank read:
Input: DC 5V 2.1A
Output: DC 5V 2.1A
Battery: 3.7V 4000 mAh (14.8 Wh)
