By Dennis
#12307
Markus Gritsch wrote:
epsoc wrote:
Code: Select allstatic uint8 remote_ipadr[4] = { 111, 222,333,444 };
333 and 444 will not fit into a uint8_t.
Yep - especially since they're not valid for ipv4 IP address octets anyway - only everything between 0 and 255 will work. ;)
regards
By plucker
#12657 Hi All,
Not sure if there is any progress, but on my side, I still have this zombie mode in my set-up: ESP-012 + DHT11 on GPIO2.
The data pin on the sensor does have a pull up...
I am using the board which have LED connected to all IOs, I may try a standalone ESP-012.
Any other idea on this zombie mode?
Thanks,
Plucker
By plucker
#13259 Hi all,
Just to confirm this zombie mode is specific to lua nodeMCU firmware, indeed I compile a native C program and didn't have this issue on the same hardware.
I think this has been mentioned in a previous post.
Conclusion, if you need deep sleep, you will have to compile your own code for the time being.
Cheers,
Plucker
