By ScheissSchiesser
#38341 When I add code to turn an LED on and turn it off with a timer, I get the following output with an error (intermittently, which is annoying):
Code: Select all
PANIC: unprotected error in call to Lua API (attempt to call a number value)
I seem to have narrowed it down to the tmr.alarm function. Is there a workaround, or perhaps a better way to leave the LED on for a second?
The following code runs just fine, no issues.
Code: Select all-- dht22_tcp_panic
print(wifi.sta.getip())
dhtpin = 2
reading = nil
ledpin = 7
gpio.mode(ledpin,gpio.OUTPUT)
srv=net.createServer(net.TCP,5)
srv:listen(8080,function(conn)
    conn:on("receive", function(client,payload)
        print("Connection received")
        -- Turn on LED
        gpio.write(ledpin,gpio.HIGH)
        -- If the payload is correct, read the DHT sensor
        if (payload == "gettemp") then
            local status,temp,humi,temp_decimal,humi_decimal = dht.read(dhtpin)
            if( status == dht.OK ) then
            -- Integer firmware using this example
            reading = string.format(
                "%d.%03d, %d.%03d",
                  math.floor(temp),
                  temp_decimal,
                  math.floor(humi),
                  humi_decimal
            readingT = string.format("%d.%03d",math.floor(temp),temp_decimal)
            readingH = string.format("%d.%03d",math.floor(humi),humi_decimal)
            elseif( status == dht.ERROR_CHECKSUM ) then
              reading =  "DHT Checksum error.";
              readingT = nil;
              readingH = nil;
            elseif( status == dht.ERROR_TIMEOUT ) then
              reading = "DHT Time out.";
              readingT = nil;
              readingH = nil;
            reading = "Wrong payload";
        print(reading)
        function sendreading ()
            print(client);
            client:send(reading);
        -- Try to send the reading
        if pcall(sendreading) then
            print("reading sent")
            print("error sending reading")
        -- Try to close the connection
        if pcall(function() client:close() end) then
            print("client closed")
            print("error closing client")
        gpio.write(ledpin,gpio.LOW)
    end)
    -- commented out, not sure if I need this
    -- conn:on("sent", function(conn) conn:close() end)
end)
Here is the full code causing the error (changes emphasized):
dhtpin = 2
reading = nil
ledpin = 7;
gpio.mode(ledpin,gpio.OUTPUT);
        -- Turn on LED and set a timer to turn it off after 1 second
-- ------------ BEGIN ADDED CODE -------------------
        tmr.alarm(1,1000,0,function()
        end)
-- -------- END ADDED CODE --------------------
                "%d.%03d, %d.%03d",
                  math.floor(temp),
                  temp_decimal,
                  math.floor(humi),
                  humi_decimal
              readingT = nil;
              readingH = nil;
              readingT = nil;
              readingH = nil;
        print(reading)
            print(client);
    end)
end)
When a connection happens:
Code: Select all
Connection received
21.700, 42.900
userdata: 3fff3bb8
reading sent
client closed
Then the module resets.
So the reading of the DHT22 is successful, so is the sending to the client, but then I get this panic. I expect that is because of the timer function.
Any thoughts on this?
EDIT: Using the following build:
NodeMCU 0.9.6 build 20150627 powered by Lua 5.1.4
By xtal
#38371 I would try a later version SDK 1.4.0 and 1.5.0 [Dev}
Todays dev build shows 1.5.0
master ver is nodemcu 140
ftightanic.com/ builds
It's my understanding that several problems were addressed by 1.4.0 ,,
Been using 140 for a while , much more available ram....
Started using 1.5.0 today , more available ram.....
