Re: Fully working MQTT examples temperature, buttons etc.
Posted: Sat Mar 21, 2015 8:07 pm
chadouming wrote:bakicc wrote:Thanks, compiling the dht22.lua worked. Be sure to have the firmware version where the node.compile method is implemented!
It's working now, great!
Why do we need to do the calculation "((temp-(temp % 10)) / 10).."."..(temp % 10)" to get the right temperature?
Why doesn't the method dht22.getTemperature() just return the right value?
Make sure you are using the firmware with float support and latest version of dht22.lua. Then you'll get correct reading using dht22.getTemperature()/10 . That is how I do it.
Thanks, going to try this!
Does this also works for the humidity?
