The esp01 is running over 10 month without problems! Not continuously, but after a reboot ( by watchdog?) the esp is very fast up again. Here an examle from the log:
2015-11-06 15:21:26.3022|INFO|up=1313266;heap=8312;E=79514;G=7234
2015-11-06 15:21:57.4585|INFO|up=27;heap=8832;E=1;G=0
Up Time was 1.3Mio seconds = 15 days.
Here is also an python script to receive the udp packets:
Code: Select allimport socket
UDP_IP = "0.0.0.0"
UDP_PORT = 15000
sock = socket.socket(socket.AF_INET, # Internet
socket.SOCK_DGRAM) # UDP
sock.bind((UDP_IP, UDP_PORT))
while True:
data, addr = sock.recvfrom(1024) # buffer size is 1024 bytes
print("received message:", data)
Output:
received message: b'up=2145;heap=8496;E=178;G=22'
received message: b'up=2158;heap=8480;E=178;G=23'
received message: b'up=2159;heap=8496;E=179;G=23'
received message: b'up=2172;heap=8480;E=180;G=23'
received message: b'up=2185;heap=8496;E=180;G=24'
received message: b'up=2198;heap=8480;E=182;G=24'
received message: b'up=2211;heap=8496;E=182;G=25'
received message: b'up=2225;heap=8480;E=184;G=25'
