By zeroday
#6646
jankop wrote:1. Flash NodeMcu 0.9.2 build 20141219 to ESP module.
2. Load program srv41.lua to ESP with Lualoader
3. HW reset module
4. Login module to your AP - wifi.setmode(wifi.STATION),wifi.sta.config("yourSSID","yourPASSWORD")
5. Test IP address - wifi.sta.getip()
6. Run program srv41.lua - dofile(srv41.lua)
7. Test it with your browser.
I do not know why, but this server does not work with the latest version NodeMcu 0.9.3 build 20141222.
Code: Select all    --wifi.setmode(wifi.STATION)
    --wifi.sta.config("yourSSID","yourPassword")
    outpin=4 -- Select right IO index !! Here is settings for GPIO2 (Lua build 20141219)
    srv=net.createServer(net.TCP) srv:listen(80,function(conn)
    --next row is for debugging output only
    print(payload)
    function ctrlpower()
    pwm.close(outpin)
    gpio.mode(outpin,gpio.OUTPUT)
    dotaz=string.sub(payload,kdesi[2]+1,#payload)
    if dotaz=="ON"  then gpio.write(outpin,gpio.HIGH)return end
    if dotaz=="OFF" then gpio.write(outpin,gpio.LOW)return end
    if dotaz=="FLC" then pwm.setup(outpin,2,512)pwm.start(outpin)return end
    pwm.setup(outpin,1000,dotaz*10)
    pwm.start(outpin)
    --parse position POST value from header
    kdesi={string.find(payload,"pwmi=")}
    --If POST value exist, set LED power
    if kdesi[2]~=nil then ctrlpower()end
    conn:send('HTTP/1.1 200 OK\n\n')
    conn:send('<!DOCTYPE HTML>\n')
    conn:send('<html>\n')
    conn:send('<head><meta  content="text/html; charset=utf-8">\n')
    conn:send('<title>ESP8266</title></head>\n')
    conn:send('<body><h1>Sample GPIO output control</h1>\n')
    conn:send('<h3>For Lua NodeMcu 0.9.2 build 20141219 only !!!</h3>\n')
   conn:send('<h3>Tested with IE 11. and Chrome 39.</h3>\n')
    conn:send('<IMG SRC="http://esp8266.fancon.cz/common/led.gif" WIDTH="150" HEIGHT="101" BORDER="1"><br><br>\n')
    conn:send('<form action="" method="POST">\n')
    conn:send('<input type="submit" name="pwmi" value="OFF">\n')
    conn:send('<input type="submit" name="pwmi" value="10">\n')
    conn:send('<input type="submit" name="pwmi" value="20">\n')
    conn:send('<input type="submit" name="pwmi" value="30">\n')
    conn:send('<input type="submit" name="pwmi" value="40">\n')
    conn:send('<input type="submit" name="pwmi" value="50">\n')
    conn:send('<input type="submit" name="pwmi" value="60">\n')
    conn:send('<input type="submit" name="pwmi" value="70">\n')
    conn:send('<input type="submit" name="pwmi" value="80">\n')
    conn:send('<input type="submit" name="pwmi" value="90">\n')
    conn:send('<input type="submit" name="pwmi" value="ON"> % of power<br><br>\n')
    conn:send('<input type="submit" name="pwmi" value="FLC"> HW blinker</form>\n')
    conn:send('</body></html>\n')
    end)
end)
try build 20150108.
By Middelbh
#7265 Hi
I tried this with newest firmwareversion (20150108) and it works, however as soon as I press a submit button the screen the screen as shown is duplicated, so I get two copies of the screen, one uner the other. Hope my problem is clear??
sample screen
Hans
By Mehrius
#7491 Hey,
I'm using parts of this code and had the same problem. Here's what I did to solve it.
I added two lines as follows:
After the
if kdesi[2]~=nil then ctrlpower() end line
add the following line:
if kdesi[2]==nil then
And then between all the conn:send stuff (the HTML stuff) and the conn:on("sent",function(conn) conn:close() end) add another line with the word 'end'.
Hope this isn't too late and that it helps.
