Post your best Lua script examples here
By dimkaf
#50803 Below my example how to use script "date.lua"https://github.com/dimkaf/NodeMCU_WebServer/blob/master/date.lua for design formatted readable date from conventional type as line value in seconds.
Code: Select all--These examples related to Date functions that maybe useful for SNTP or RTC data conversion from seconds format to conventional variables like minutes hours or year and month
-- IMPORTANT: code for integer version only, in the case float firmware use int format or floor functions
local xx,dd,mm,yy,hh,mn,ss,sc
local wd={"Sun","Mon","Tue","Wed","Thu","Fri","Sat"};
sc=1468252705; --Mon Jul 11 2016 18:58:25 GMT+0300 (RTZ 2 ,winter)
require("date")
hh,mn,ss =Date.GetTime (sc,3) -- calculate time stamp for GMT+0300
dd,mm,yy =Date.GetDate(sc) -- calculate data time stamp
xx =wd[1+Date.GetDay(sc)] -- define day of week
print(xx..". "..dd.."/"..mm.."/"..yy.."   "..hh..":"..mn.."'"..ss) --show result as formated string day/month/year hours:minutes'seconds
hh,mn,ss =Date.GetTime (_,4) -- calculate time stamp from RTC on board using local time shift GMT+0400
