Re: MQTT for NodeMCU Lua working NOW
Posted: Tue Jan 27, 2015 10:22 am
Hello guys,
I am having a problem, where I hope somebody can help me out, since I am not an expert on Lua.
I put the following code into "init.lua" file
But when I restart the ESP8266, console says:
What am I doing wrong here?
PS: I flashed the device with ESP8266Flasher.exe from https://github.com/nodemcu/nodemcu-flasher
Thank you
mqtt.Client("clientid", 120, "user", "password")
m:lwt("/lwt", "offline", 0, 0)
m:on("connect", function(con) print ("connected") end)
m:on("offline", function(con) print ("offline") end)
m:on("message", function(conn, topic, data)
print(topic .. ":" )
if data ~= nil then
print(data)
end
end)
m:connect("192.168.4.2", 1984, 0, function(conn) print("connected") end)
m:subscribe("hello_world",0, function(conn) print("subscribe success") end)
m:publish("test_publish","hello",0,0, function(conn) print("sent") end)
lua: init.lua:2: attempt to index global 'mqtt' (a nil value)
Thank you
