By amera64
#7654 I have been working with the MCP9808 temp module from Adafruit and got it to work with the ESP8266 with Lua nodeMCU. Here is the code if anyone is interested.
Wiring:
GPIO0 -> sda on mcp9808
GPIO2 -> scl on mcp9808
Code: Select allid=0
sda=3 --GPIO0
scl=4 --GPIO2
i2c.setup(id, sda, scl, i2c.SLOW)
function read_reg(dev_addr, reg_addr) -- Read MCP9808 data
  i2c.start(id)
  i2c.address(id, dev_addr ,i2c.TRANSMITTER)
  i2c.write(id,reg_addr)
  i2c.stop(id)
  i2c.start(id)
  i2c.address(id, dev_addr,i2c.RECEIVER)
  c=i2c.read(id,2)
  i2c.stop(id)
  return c
function convert(tempval) -- convert 2 byte value
  t = tonumber(string.byte(tempval,1))
  t = bit.lshift(t,8) + tonumber(string.byte(tempval,2))
  temp = bit.band(t, 0x0FFF) / 16
   if t > 127 then t = t - 255 end
  return temp
function toFahrenheit(ctemp) -- convert Celcius to Fahrenheit
  ftemp = ctemp * 9 / 5 + 32
  return temp
print("Temp=",toFahrenheit(convert(read_reg(0x18, 0x05))))
