MCP9808 I2C temp module
Posted: Sun Jan 18, 2015 9:56 pm
I have been working with the MCP9808 temp module from Adafruit and got it to work with the ESP8266 with Lua nodeMCU. Here is the code if anyone is interested.
Wiring:
GPIO0 -> sda on mcp9808
GPIO2 -> scl on mcp9808
Wiring:
id=0
sda=3 --GPIO0
scl=4 --GPIO2
i2c.setup(id, sda, scl, i2c.SLOW)
function read_reg(dev_addr, reg_addr) -- Read MCP9808 data
i2c.start(id)
i2c.address(id, dev_addr ,i2c.TRANSMITTER)
i2c.write(id,reg_addr)
i2c.stop(id)
i2c.start(id)
i2c.address(id, dev_addr,i2c.RECEIVER)
c=i2c.read(id,2)
i2c.stop(id)
return c
end
function convert(tempval) -- convert 2 byte value
t = tonumber(string.byte(tempval,1))
t = bit.lshift(t,8) + tonumber(string.byte(tempval,2))
temp = bit.band(t, 0x0FFF) / 16
if t > 127 then t = t - 255 end
return temp
end
function toFahrenheit(ctemp) -- convert Celcius to Fahrenheit
ftemp = ctemp * 9 / 5 + 32
return temp
end
print("Temp=",toFahrenheit(convert(read_reg(0x18, 0x05))))
