By Raoulos
#16500 Hi,
First thx, i use the last firmware, it's works on arduino and when i test it with the esp8266(i use the Esp-07), it do that:
Publishing...25
Publishing...24
Publishing...23
Publishing...22
Publishing...21
Publishing...25
Publishing...24
Publishing...23
Publishing...22
Publishing...21
Publishing...25
Publishing...24
It restart everytime after 21. The time between each "Publishing" is around 5-6sec
Do you have any idea ?
By rutierut
#16723
Raoulos wrote:Hi,
Publishing...25
Publishing...24
Publishing...23
Publishing...22
Publishing...21
Publishing...25
Publishing...24
Publishing...23
Publishing...22
Publishing...21
Publishing...25
Publishing...24
Yes, that is how the script is designed, after 5 seconds it tries to publish again, apparently the ESP fails to publish to the broker.
By bubnikv
#21662 Dear Rutierut,
I am in a need for a remote tuning knob for a software defined radio running on the other side of the house. I would like to transmit the state of the rotary encoder with low latency over WiFi.
Would you please elaborate on why the immediate reporting of the rotary encoder state is not stable? Does the WiFi processing block the reading of the rotary encoder state? If so, would it then help to let an external low cost controller handle the rotary encoder and let the Lua script poll the external low cost controller for the state of the rotary encoder?
Thanks, Vojtech
