Left for archival purposes.
By milikiller
#8274 Hi, I use ESP-12 from Aliexpress, and have swaped 4 and 5 GPIO. I try pinout on my ESP-12 board, and working good.
the code changes is in "pin_map.c"
Code: Select all#include "pin_map.h"
#include "eagle_soc.h"
#if 0
uint32_t pin_mux[GPIO_PIN_NUM] = {PERIPHS_IO_MUX_MTDI_U,  PERIPHS_IO_MUX_MTCK_U,  PERIPHS_IO_MUX_MTMS_U,     PERIPHS_IO_MUX_MTDO_U,
                          PERIPHS_IO_MUX_U0RXD_U, PERIPHS_IO_MUX_U0TXD_U, PERIPHS_IO_MUX_SD_DATA2_U, PERIPHS_IO_MUX_SD_DATA3_U,
                          PERIPHS_IO_MUX_GPIO0_U, PERIPHS_IO_MUX_GPIO2_U, PERIPHS_IO_MUX_GPIO4_U,     PERIPHS_IO_MUX_GPIO5_U};
uint8_t pin_num[GPIO_PIN_NUM] = {12, 13, 14, 15,
                          3,  1,  9, 10,
                          0,  2,  4,  5};
uint8_t pin_func[GPIO_PIN_NUM] = {FUNC_GPIO12, FUNC_GPIO13, FUNC_GPIO14, FUNC_GPIO15,
                          FUNC_GPIO3,  FUNC_GPIO1,  FUNC_GPIO9,  FUNC_GPIO10,
                          FUNC_GPIO0,  FUNC_GPIO2,  FUNC_GPIO4,  FUNC_GPIO5};
#ifdef GPIO_INTERRUPT_ENABLE
GPIO_INT_TYPE pin_int_type[GPIO_PIN_NUM] = {
                        GPIO_PIN_INTR_DISABLE, GPIO_PIN_INTR_DISABLE, GPIO_PIN_INTR_DISABLE, GPIO_PIN_INTR_DISABLE,
                        GPIO_PIN_INTR_DISABLE, GPIO_PIN_INTR_DISABLE, GPIO_PIN_INTR_DISABLE, GPIO_PIN_INTR_DISABLE};
#endif
#else
uint32_t pin_mux[GPIO_PIN_NUM] = {PAD_XPD_DCDC_CONF,  PERIPHS_IO_MUX_MTMS_U,  PERIPHS_IO_MUX_MTDI_U,     PERIPHS_IO_MUX_MTCK_U,
                          PERIPHS_IO_MUX_MTDO_U, PERIPHS_IO_MUX_GPIO2_U, PERIPHS_IO_MUX_GPIO0_U, PERIPHS_IO_MUX_GPIO4_U,
                          PERIPHS_IO_MUX_GPIO5_U, PERIPHS_IO_MUX_U0RXD_U, PERIPHS_IO_MUX_U0TXD_U, PERIPHS_IO_MUX_SD_DATA2_U,
                          PERIPHS_IO_MUX_SD_DATA3_U };
uint8_t pin_num[GPIO_PIN_NUM] = {16, 14, 12, 13,
                         15,  2,  0,  4,
                          5,  3,  1,  9,
                         10};
uint8_t pin_func[GPIO_PIN_NUM] = {0, FUNC_GPIO14, FUNC_GPIO12, FUNC_GPIO13,
                          FUNC_GPIO15,  FUNC_GPIO2,  FUNC_GPIO0,  FUNC_GPIO4,
                          FUNC_GPIO5,  FUNC_GPIO3,  FUNC_GPIO1, FUNC_GPIO9,
                          FUNC_GPIO10};
#endif
#endif
