i'm not developper so i have not successfully get datas and pulled to LUA.
the french teleinfo is simple uart with these parameters :
speed 1200
8 bits but only 7 data bits
no parity
1 stop bit
LUA can't easy manipulate bytes, so i've try to modify the NodeMCU Firmware.
I'm able to display the correct datas with these lines added to /app/modules/uart.c :
bool uart_on_data_cb(const char *buf, size_t len){
if(!buf || len==0)
return false;
if(uart_receive_rf == LUA_NOREF)
return false;
if(!gL)
return false;
lua_rawgeti(gL, LUA_REGISTRYINDEX, uart_receive_rf);
[color=#0040FF]char *char_teleinfo;
int charpos;
while (charpos<len)
c_printf("%c", buf[charpos]&0x7f);
charpos++;
}[/color]
lua_pushlstring(gL, buf, len);
lua_call(gL, 1, 0);
return !run_input;
}but i'm unable to pull this to LUA...
I just want to migrate from a big arduino to a small powerful ESP8266...
the arduino code is like this :
#include <SoftwareSerial.h>
#define startFrame 0x02
#define endFrame 0x03
SoftwareSerial* cptSerial;
void setup()
Serial.begin(9600);
cptSerial = new SoftwareSerial(8, 9);
cptSerial->begin(1200);
Serial.println(F("setup complete"));
void loop()
char charIn = 0;
while (charIn != startFrame)
charIn = cptSerial->read() & 0x7F;
while (charIn != endFrame)
if (cptSerial->available())
Serial.print(charIn);
Serial.println("");
}I've created an teleinfo emulator based on arduino :
change Serial interface as you need or convert with SoftwareSerial :
Serial1.begin(1200,SERIAL_7E1);
Serial1.print((char) 0x02);
Serial1.print( (char) 0x0A);
Serial1.print("ADCO 012345678901 F");
Serial1.print( (char) 0x0D);
Serial1.print("OPTARIF HC.. <");
Serial1.print("ISOUSC 20 8");
Serial1.print("HCHC 036424518 '");
Serial1.print("HCHP 026582379 =");
Serial1.print("PTEC HP.. ");
Serial1.print("IINST1 003 K");
Serial1.print("IINST2 000 I");
Serial1.print("IINST3 001 K");
Serial1.print("IMAX1 019 :");
Serial1.print("IMAX2 020 3");
Serial1.print("IMAX3 018 ;");
Serial1.print("PMAX 08380 9");
Serial1.print("PAPP 00970 1");
Serial1.print("HHPHC E 0");
Serial1.print("MOTDETAT 000000 B");
Serial1.print("PPOT 00 #");
Serial1.print((char) 0x03);
}Regards
