module, reading from a DS18B20. Digging through ow.c and onewire.c
the C code matches code which I know works when called directly
from C on an Arduino, but which on the ESP8266 just returns a
string of 0xff bytes. Single reads work correctly in both cases.
Probably the solution is to build NodeMCU locally with additional
debugging statements, but before I do that I thought I'd ask if
anyone else had seen the problem.
Thanks - Will
