Chat about current Lua tools and IDEs
By ok1cdj
#5434 The snippet saving does not work on Linux:
Code: Select allPro 22, 2014 4:28:14 ODP. ESPlorer.ESPlorer log
INFO: Snippets (LUA) load: Success.
Pro 22, 2014 4:28:40 ODP. ESPlorer.ESPlorer log
INFO: Snippet0 saved.
Pro 22, 2014 4:28:42 ODP. java.util.prefs.FileSystemPreferences syncWorld
WARNING: Couldn't flush system prefs: java.util.prefs.BackingStoreException: /etc/.java/.systemPrefs/com create failed.
User can't wite to /etc/
The file need to be saved to home_dir/.java...
Regards, Ondra
By hreintke
#5452 LS,
Running on Windows 8.1
- Settings are not saved.
In the logfile I get the following remark :
Code: Select all<record>
  <date>2014-12-22T17:45:19</date>
  <millis>1419266719020</millis>
  <sequence>14</sequence>
  <logger>ESPlorer.ESPlorer</logger>
  <level>INFO</level>
  <class>ESPlorer.ESPlorer</class>
  <method>log</method>
  <thread>13</thread>
  <message>Load saved settings: NOT FOUND. Used default settings.</message>
</record>
What is the expected location of the settings file ?
Also snippets are not saved. Each session starts with empty environment.
Herman
By 4refr0nt
#5499 New version v0.1 build 202 released.
Full ChangeLog
ChangeLog for this version
    add "Inc/Dec font size" commands for editor, terminal and log windows. See screenshoot (for Pigs Fly)
    remove all terminal autoclear actions (for scargill)
    bug fix - save settings on some platforms (for Ondra and Herman)
Attention!
Because "save settings" procedure changed, you can't load settings (include snippets) saved by prev version v0.1 build 201
You must save you snippets to external file, then paste to snippets editor in v0.1 build 202
P.S.
Hi, Herman!
Special features for you in process, but not yet done.
By 4refr0nt
#5500 Hi, All!
My English is very bad, and I need help for make ESPlorer UI spelling-errors-free.
If you find any spelling or other error in ESPlorer UI, then, please, tell me about this.
Thanks!
