Page 6 of 13
Re: Build your own custom NodeMCU firmware in the cloud
PostPosted: Fri May 15, 2015 9:20 am
by squix78
Hi Marcel
Thanks a lot! It looks and works really nice. Any chance you will include a selector for the fonts used by u8glib?
By the way: I compared the difference it makes on the heap and between your 7 default modules and the original module it's more than 5KB! Not bad if you desperately need some additional heap space:
http://blog.squix.ch/2015/05/esp8266-nodemcu-custom-build.html
Cheers,
Dani
PostPosted: Fri May 15, 2015 9:58 am
by marcelstoer
Sure, why not...the list goes on and on ;-) The appetite comes with eating.
I see that https://github.com/nodemcu/nodemcu-firm ... onfig.h#L9 allows to configure fonts. What are the valid values? https://github.com/nodemcu/nodemcu-firm ... glib/u8g.h contains lots of variants. Furthermore, it'd also be nice to get a graphic example for each font the page offers so users can make up their minds.
PostPosted: Fri May 15, 2015 11:02 am
by squix78
I think they should correspond to these here:
https://code.google.com/p/u8glib/wiki/fontsize
PostPosted: Tue May 19, 2015 1:03 am
by marcelstoer
Here's an update on the feature requests posted in this thread.
axelk wrote:A nice improvement would be to add an option to disable SSL
This is done but currently read-only in the UI due to NodeMCU bug #432
cal wrote:add more information into the version string thats printed on startup. Just the list of modules and some important flags used for config.
Next on my list.
squix78 wrote:Any chance you will include a selector for the fonts used by u8glib?
Currently in the making, marked read-only in the UI. The back-end is done but I'm struggling a bit with the sensible presentation of several 100 font faces in the UI. The main screen will just have a text field to enter a comma separated list of font names as expected by NodeMCU but to help you with the selection there's a separate window with checkboxes whose state will feed the text field.
Most notable (but not visible), however, is that I reworked the entire back-end to be able to add more features with very little effort in the future.
http://frightanic.com/nodemcu-custom-build/
