Let me be the first to say "WELL DONE" - I got up this morning (UK based) and noted the update before I read this blog. The timer works (2 seconds) and I can reload files without error. Finally I can start looking at the various functions without the thing falling over. I'll write a blog item later this morning over at
http://scargill.wordpress.com for those looking in (and there are quite a few).
I do have a couple of questions. Bear with me as this might sound dumb..
Let's say we have a file which has a function definition in it... and that gets called at power up as I do.. It I then delete the file and over-write it and call it again - does the existing stored function get over-written or do we need to reboot. As you can imagine, while developing functions there are going to be continual errors along the way.
I could see some serious uses for this - I just hope there is enough memory to store a decent amount of code in the unit.
Suggestion for you - the ESP-01 has at best 2 wires to play with - it would be really nice if one could read the likes of the Dallas 1-wire temperature chips on one of them. In the simplest case that opens the possibility of WIFI controlled temperature control (Dallas chip and a relay) using the ESP-01 and no host processor - wouldn't that be good.
Regards
Pete.
