By GeoNomad
#4286
zeroday wrote:Build 20141207
    4, modify gpio.mode() api, add internal pullup/float para.
Thank you for this. It's like having you guys on staff.
It is important to note that the default has changed from pullup to float. This will cause some hardware to not function if they update the firmware without paying attention to the new default.
By GeoNomad
#4288
zeroday wrote:Change log:
2014-12-08
add uart.setup(), uart.write() api.
close echo in uart.setup()
Fantastic and so useful:
Code: Select allfunction monitor( pin )
   uart.write( 0, ''..gpio.read(pin) )
gpio.mode(9,gpio.INPUT,gpio.PULLUP)
tmr.alarm( 50,1,function() monitor(9) end )
Morse Decoder, anyone?
1111100000111011000001110111111100000110000001110110000011111111
Should work down to 10 mSec or so.
