Re: Read serial from Arduino
I don't understand why with another sketch it work anyway. I will try with the resistor. Thanks
Open Community Forum for ESP8266, Come share Arduino and IoT (Internet of Things)
https://www.esp8266.com/
hwiguna wrote:Interestingly, eventhough I've been using 1K and 1.8K resistor ladder to bring 5V SIGNAL from the FTDI TX to the ESP RX, I have not used anything beetwen the ESP TX and FTDI RX.
Furthermore, I did not use ANY level shifting on the Arduino Mega.
It is very curious that you do not see the Arduino RX not blinking. Have you double-checked that the RX and TX between the two devices are crossed?
zioax wrote:hwiguna wrote:Interestingly, eventhough I've been using 1K and 1.8K resistor ladder to bring 5V SIGNAL from the FTDI TX to the ESP RX, I have not used anything beetwen the ESP TX and FTDI RX.
Sure, all the connection are right. I've also added a resistor on the RX pin but the problem still persists, the RX pin on Arduino doesn't turn on!!
