Re: simple delay, wait or pause function
Posted:
Fri May 15, 2015 9:01 am
by joefly888
John, This worked easily. Thanks
Posted:
Fri May 15, 2015 10:04 am
by j0hncc
That's good!
Maybe you figured this out, but my code was wrong, it should actually be
Code: Select alltmr.alarm( 0, 2000, 0, turnOffLed )
Third parameter is 0==once, 1==repeating
Posted:
Fri May 15, 2015 10:54 am
by joefly888
Thanks for the heads up, I did not notice, as the LED was always otherwise off, so I did not notice it repeatedly turning it off. But I did correct my code thanks.
That leads me to ask, what is the 1st parameter of "0" do?
Thanks again
Posted:
Fri May 15, 2015 11:16 am
by j0hncc
Oh that is the timer number 0-6, you can decide which of these do what.
You do know about this reference page, right?
https://github.com/nodemcu/nodemcu-firmware/wiki/nodemcu_api_en#new_gpio_mapSee Timer Module.
But generally avoid using tmr.delay !
Cheers,
John
