- Fri Nov 10, 2017 2:40 am
#71724
Thank you for your reply.
I've latest stable version of Nodemcu LUA firmware: 2.1.0-master_20170824
I don't think that this is the software issue.
First of all I have to confirm, that you used the right pins, all of them are for HSPI. I believe that using any others can lead to hangs and reboot. This was exactly what I observed and later I remember, that I've already reported this problem:
https://github.com/nodemcu/nodemcu-firmware/issues/1602 So I've changed to:
local MISO = 6 --> GPIO12
local CLK = 5 --> GPIO14
local CS = 8 --> GPIO15
But there is one more (or even more
) issue. I'm afraid it is not ESP even software issue, but the modules one. I found description of very similar problem here:
http://forum.arduino.cc/index.php?topic=155641.0Now it seems to me that something wrong is with MAX module. Can you pls specify which kind of MAX31855 module is used in your project?
I'm using MAX31855K chip (probably version 1.0):
Also, I'm not sure if the Thermocouple Probe is connected right, is red for minus and blue for plus? Anyway I've try both variants without the reasonable result.
Which MAX module is in your project?
Thank you for answer.
Roman
