nodeMPU vs. ES8266-01 compatibility
Posted: Tue Oct 01, 2019 4:10 pm
I'm starting a home electric load-leveling project and discovered IFTTT for Smart Thermostats, etc. The available T-stat's respond to IFTTT invokings ("Then" actions) but don't create "This" triggers upon their own actions. However, there is a ESP8266-01 project (https://www.hackster.io/noelportugal/if ... ton-e11841) that will act as a trigger to an IFTTT Applet. It looks very hackable to make triggers for lots of events, including changing voltages on the T-stat to A/C unit wires. One problem the ESP8266-01 module only breaks out 2 of the 8266's 16 GPIO pins and one is used to make the .lua script work. That doesn't leave much hacking freedom. Behold, the modeMPU module with all the of 8266 GPIO pins available to us! My question is, given that relevant libraries are copied, would .lua scripts from ESP8266-01 development work in modeMPU development?
