By Venkatesh
#38072 J.G.Aguado : you are saying it worked for you. are you sure ? I cannot even connect to api.telegram.org using WifiSecureClient. Any suggestions ?
By Nightmystic
#42122
J.G.Aguado wrote:
J.G.Aguado wrote:Hi,
Very good post, unfortunatelly using the ESP8266TelegramBOT library i can only get the message:
Code: Select all...
WiFi connected
IP address:
192.168.10.61
GET Cookies
GetUpdates
GET Update Messages
fialed to updateGetUpdates
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
GET Update Messages
I don't know what is happening ... If I upload the other lib, the TelegramBOT lib i get the same as Lstt...
Hi, I solved the error: the API token wasn't properly copied
I have the same issue, but I cannot seem to get it right, can you explain what was wrong with how the token was entered and what you did to make it work?
By arjun
#58500 hiiii
i got a problem using nodemcu v3 esp8266. i sent a text via telegram to the nodemcu but he can't read if/if else command and he don't reply my message
