By FlyingHacker
#20855 The eps tool is automatically called now, and you don't have to select it from the programmer menu. It is not there...
I had a lot of trouble ever getting the ESP-01 to work with a CHI based serial to usb connector. Once I used the FT232 based adapter like this:
http://www.ebay.com/itm/201332938880?_t ... EBIDX%3AIT
It worked perfectly. With the DTR and RTS you don't have to manually push any buttons or manually pull up or down any pins in order to program the the Arduino IDE. It just works!
Wire it up like the first diagram on this page
https://github.com/esp8266/Arduino
Minimal hardware Setup for Bootloading and usage section of that page.
It should work great.
Now this can have issues with the serial monitor. Perhaps the 1.6.5 IDE has fixed this... Have not tried it yet.
By Shivank
#20904
tytower wrote:1.6.5 Arduino is out.
Yours is not syncing with the chip to upload . check all wirings and search on this board . Same issue over and over .
Thanx tytower you are absolutely correct about the wiring.My wirings are loose thats why I face this error...Thank God it uploads now perfectly.Thanks once again. :)
