By sang_sorn
#18233
quintinjvr wrote:Had the same problem. After lots of trail and error I found that you need to have GPIO0 connected to ground when powering up, then remove ground from GPIO0 and then upload. Strange but seems to work for me. (ESP 8266 101)
It's work! Thanks!!
By PawnDrifter
#18466 I found this helpful thread that I somehow missed the first time:
http://www.esp8266.com/viewtopic.php?f=26&t=2245
It describes how the Arduino IDE will overwrite any firmware already loaded. Doh! But that is a good thing if you want to use the Arduino IDE anyway.
I also experienced a failure to communicate with the Arduino 1.6.4 IDE and 8266 Generic board type on my ESP8266-07.
I am currently stuck at this point with communications, but have learned a little since then. I'll go back and give it a go.
I did use Termite at 74880 bps to watch the exchange on reboot of the module.
I received the following stream:
ets_main.c [00]
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
By froggy
#18885 Im having the same problem with a 201 no matter what i try i get
error: failed reading byte
warning: espcomm_send_command: cant receive slip payload data
warning: espcomm_sync failed
error: espcomm_open failed
