By PieGa
#37766 Hi Guys,
I have a problem, I installed the ESP-01 and i will programming with arduino IDE on my new iMac (El Capital). The Problem is that i can "read" the ESP with the serial monitor:
" Ai-Thinker Technology Co.,Ltd.
ready
but if I send a a program like this one:
Code: Select allint ledState = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
  pinMode(BUILTIN_LED, OUTPUT);
void loop()
  if(currentMillis - previousMillis >= interval) {
    if (ledState == LOW)
      ledState = HIGH;  // Note that this switches the LED *off*
      ledState = LOW;   // Note that this switches the LED *on*
    digitalWrite(BUILTIN_LED, ledState);
I have this error:
error: failed reading byte
warning: espcomm_send_command: cant receive slip payload data
warning: espcomm_sync failed
error: espcomm_open failed
On internet I find this: http://hpclab.blogspot.mx/2015/06/esp82 ... -os-x.html
but I don't understand how install the esptool. Can you help me?
Thanks
By ima747
#38020 Check my thread at viewtopic.php?f=26&t=7366&start=4. I had trouble verifying the wiring, getting the correct mode, and getting the arduino IDE and esptool.py up and running but sorted it all out in the end. Details in the last post there, hopefully it will provide a bit of guidance.
