By d1414213562
#41831 Thank you on your constant help. Changing to the nodemcu fixes the problem of repeated upload, now this error does not appear anymore.
But the original problem persists. Still no program is left in flash after power is disconnected.
By Fernando Garcia
#41848
d1414213562 wrote:Thank you on your constant help. Changing to the nodemcu fixes the problem of repeated upload, now this error does not appear anymore.
If it can help, I have just the same problem.
I have sketch that measure temperature, humidity and a sensor and upload the data to a MQTT server. If works well during days, but when I disconnect (just after uploading the sketch of after many hours) it lost its configuration.
I tested with two different NodeMCU of different manufactures with the same outcome.
By martinayotte
#41863
d1414213562 wrote:Still no program is left in flash after power is disconnected.
I don't think the Flash is emptied at all. I'm still convince that it is a Boot mode issue where GPIO2/GPIO0 are not HIGH when power is recycled, for some unknown reason.
By d1414213562
#41866
And you were right! GPIO0 had a short circuit to the ground due to manufacture error of PCBs on which ESP was soldered on. Because of that, on every power-on it went to the bootloader mode..
@Ferndando, you might also for this mistake. Use the multimeter and measure resistance between GPIO0 / GPIO2 and gnd / 3.3V. If any mistakes as mine, you will see them.
