I'm designing a PCB where I want ESP run in normal mode, but I can connect through header to program ESP please refer to images.
Please look at my schematic U10 is programming header, I will connect it to ESP-01 header (please refer to image)
Explore... Chat... Share...
sairfan06 wrote:I'm using ESP12E and i believe i have to pull up GPIO 2 and pull down GPIO 15, is that right?
if you pull down GPIO15 with 10k resistor for boot, then in the program (after boot) can i send signal with state HIGH
It's a fake post and a copy of an actual Reddit p[…]
It shouldn't be a real problem; it actually depend[…]
you shouldn't need to use any wires for flashing, […]
There are the Wemos D1 Mini WiFi Module ESP8266 18[…]
the TMP117 has been delvered today. I connected th[…]
Then I think the PCB indeed already had a small de[…]
It has been a while since I used Arduino IDE with […]
Do you find the answer to your question? I'm also […]
Hi guys! I’ve got a file.txt saved in my LittleFS […]
Might be helpful for beginners like me: After fol[…]
Hello, Im currently working on how to connect fire[…]
Follow US on Twitter and get ESP8266 news and updates first.
