Chat here is you are connecting ESP-xx type modules to existing AVR based Arduino
By weisslein
#21262 oh my godness. I've solved the issue. :)
the wires were not correctly connected. I've plugged the board with male pins into the breadboard, but I forgot to solder the pins together with the board.
I found out that issue, after I used my multimeter. after soldering the board with the pins the board boots and the uploads works without any problems.
thanks so much for your help!! :D
