I try to connect the Lightintensity modul BH1750FVI to the ESP8266. Sadly until now, it will not work. I've connected SCL to GPIO5 and SCA to GPIO4. Pullup resistors to VCC also connected. I get only the value 54612.
I use the LIB from http://www.instructables.com/id/BH1750- ... /?ALLSTEPS. During compile there is no error.
Now the question: Which are the I2C pins? How to init I2C correctly? I think I use the wrong Pins? How can I define SCL and SCA Pins? I have also tryed to add the command Wire.pins(5,4); but then the compile says this command is deprecated.
Thanks in advance, Bernd
Edit: I added Wire.begin(); in the setup but no changes.
