By DAFlippers
#59462
You are actually incorrect, the second edit as you say is a totally different post. If you are going to continue to be petty about edits then just dont reply mate.
I do apologise. I was confused because you posted exactly the same quote above the second post so it looked to be the same post.
David
By Joe Job
#59464
DAFlippers wrote:fit 0.1uF capacitor across the power rails as close to the device as possibleç
RE this, I do remember it came up before just not since discussing the issue at the latest stages, how about physically soldering the capacitor to the VCC and GND pins?
Also the 100uF I mentioned was in relation to the output of the regulator, I did get mixed up on this.
By rudy
#59467
AdamMiltonBarker wrote:
rudy wrote:The problem is ....
Well thank you that was not hard was it ;)
I went in early to work in order to work on my own project but instead I ended up spending that half hour on answering your issue. I would rather have got my own stuff done.
