Before I switched from 2.4.2 to 2.3.0, I had temperature values of -16º C after I had 28º C which is about the right value.
So it seems something about the Arduino Core 2.4.2 made the ADC read the wrong value
Explore... Chat... Share...
#include <SimpleKalmanFilter.h>
#define e_mea 2.0 //Measurement Uncertainty
#define e_est 2.0 //Estimation Uncertainty
#define q_pn 0.01 //Process Noise
SimpleKalmanFilter KalmanFilter(e_mea, e_est, q_pn);
unsigned int sensorValue, sensorValueKalman;
void setup
void loop()
sensorValue = analogRead(A0);
sensorValueKalman = KalmanFilter.updateEstimate(sensorValue);
// do y=mX +C adjustments here
