By Sandrino
#84502 Hi there,
with 2.6.0 and 2.6.1
when compiling any sketch that includes either:
#include <WebSocketsClient.h> from library https://github.com/Links2004/arduinoWebSockets
or
#include <WebSocketsServer.h>
I get a ton of error: unknown type name 'uint32_t' and cannot compile.
I I switch back to 2.5.1 everything is fine.
Any Idea ?
Update:
I-ve installed under windows 10 the same arduino ide 1.8.10 and the same libraries and there works.
i-ve installed under a new linux suse machine, same ide same lib... Same error !
tried to erase old version, tried to cancel directory but nothingh works.
also neither esp8266 sketch data file upload works:
esptool write_flash: error: argument <address> <filename>: Must be pairs of an address and the binary filename to write there
SPIFFS Upload failed!
So what is the difference between Linux an Windows .
Can someone help ???
By Sandrino
#84580 Yes ! You did it ! Many Thanks.
Just for to help people that has the same issues, on Linux the complete path for 2.6.1 is:
/home/<whatever is your accounts name here> /.arduino15/packages/esp8266/hardware/esp8266/2.6.1/cores/esp8266
add at the very beginning:
... You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <stdint.h> <<<<<<<<<<<<<<<<<< this line is to be added
#ifndef CORE_ESP8266_FEATURES_H
#define CORE_ESP8266_FEATURES_H
