By martinayotte
#15697 Hi IGRR,
I won't argue about the way to fix that latency since I don't have the knowledge for that, but I'm sure you understand that having 150ms on every packets sent is an issue. Maybe the bug is somewhere else then...
By reaper7
#16294 I have :roll: but I wrote about this earlier...
so, two images say more than thousand words:
old with oryginal delay, open jpg image from esp (15.82kB 320x240) -> 37,37s!!!:
new with Chris--A mod tcp_output(_pcb), open jpg image from esp (16.16kB 320x240) -> 1,84s!!!:
No other changes, only delay replace with tcp_output.
I don't say that use tcp_output instead delay are correct, maybe problem exists somewhere else but at this moment I applied this change and I no see any negative effects
By Chris--A
#16325 IGRR mentioned how my change cause the code to not wait for ACK packets.
Rather than replacing the delay(5000), try adding the call to tcp_output before it. This way ACK's are still received.
It might not improve the latency as much, but might make a difference.
