Hi all.
If I use system_deep_sleep, it doesn't sleep and no UDP is sent? It does seem to reset.
If I use ESP.deepSleep, it sleeps, gets the time, but no UDP data is sent?
Either way, UDP is not sent even once (before deep sleep).
If I don't use any deep-sleep, everything works.
Any ideas?
I'm not ready to set-up a MTTQ broker.
MTTQ seems more common and I haven't seen any problems with deep sleep.
IDE 1.6.10, esptool.exe 0.4.9, Win10 x64
Code: Select all//extern "C" { // For 'system_deep_sleep()'
//#include "user_interface.h"
#include <WiFiUdp.h>
#include "TimeClient.h"
float utcOffset = 9.5; // enter your UTC
TimeClient timeClient(utcOffset);
const char* ssid = "SSID";
const char* password = "Password";
IPAddress ipBroadCast(192, 168, 1, 200); // Destination IP
const unsigned int udpRemotePort = 8889; // Destination Port
const int sleepTimeS = 3; // Deep sleep time (s)
const int UDP_PACKET_SIZE = 10; // excluding NL character
char udpBuffer[UDP_PACKET_SIZE];
WiFiUDP udp; // setup UDP object
//////////////// SETUP ///////////////
Serial.begin(57600);
delay(100);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
Serial.print("IP address: ");
Serial.print("Destination IP address: ");
Serial.println(ipBroadCast);
Serial.print("Port: ");
Serial.println(udpRemotePort);
Serial.println("Starting UDP");
timeClient.updateTime();
//String time = timeClient.getFormattedTime();
strcpy(udpBuffer, "abcdefghij"); // Debug message
udp.beginPacket(ipBroadCast, udpRemotePort);
delay(10);
udp.write(udpBuffer, sizeof(udpBuffer));
delay(10);
udp.endPacket();
udp.flush(); // not required (doesn't help)
Serial.print("Sent: ");
Serial.println(udpBuffer);
//// SLEEP ////
Serial.println("Entering sleep mode...");
Serial.println("");
//WiFi.forceSleepBegin();
//ESP.deepSleep(sleepTimeS * 1000*1000, WAKE_RF_DEFAULT); // or WAKE_RFCAL or WAKE_NO_RFCAL or WAKE_RF_DISABLED or WAKE_RF_DEFAULT
//ESP.deepSleep(3 * 1000*1000);
//system_deep_sleep(3 * 1000*1000);
Serial.println("Exiting sleep mode...");
delay(1*1000);
