Re: WIFI SCAN AND ACQUIRE OLED
Posted: Sat Sep 17, 2016 9:46 am
It's been a lot of fun Dans and I should also thank Mikejstb for the way he introduced the sprintf method..which was new learning !
Have been here a while, sort of as a lurker and have no idea how to edit posts. I realised pretty fast that pics and the code itself should have been in the original post, not many want to click on YouTube links (I don't 'monetize' the channel at all, no adverts etc).
Anyway, there is a Beta version of a clock now, instead of Thingspeak data.
It will run for about 45 seconds once connected to home WiFi and showing the time, but then both an ESP-01 and ESP-03 bomb out with an Exception (20) error
It's fine for a quick switch on, checking the time and switch off and will loop as usual when scanning AP's, but that's no solution !!!!
This may be a broader issue than your thread/wrong section for working through. i'd welcome any advice on fixing it.
i also noted something about a large Font ? and would like to put large numbers on the OLED for the time
Code is attached (replaces the original .ino. The OLED and Fonts files should also be in the same folder for use in the Arduino IDE).
Pic of Scanner-01 build:
