Re: How to talk to CN105 of a mitsubishi heat pump
Posted:
Mon Feb 06, 2017 3:32 pm
by SwiCago
Albertooo wrote:Hi swicago,
Can you help me?
My european unit pead rp100 ja dont work with this tructure header bytes.
i have wifi adaptor mac-55-ife7 and works well
How could I figure out the byte structure of my heat pump?
I made your schema with wittycloud esp8266 and my heat pump does nothing.
Thanks in advance
Albertooo wrote:with hadley code python and raspberry connected with heat pump with usb to ttl, i can see the header and the protocol?
Thanks in advance!!!!
Regadrs
Make sure you have the pull up resistors on TX and RX. It did not work for me either, until I did this.
BTW, Hadley's is in NZ and I am in US, both of our units work based off his original python. SO I would be very surprised if EU had a different protocol, especially if the connector is cn105 as well.
You can also use a RaspPi and Hadley's python just to see it work with his code. It may also need pull ups on TX and RX.
Posted:
Mon Feb 06, 2017 4:10 pm
by SwiCago
Hi Albertooo, I see you figured it out. I saw your post on Hadley's blog. I see you turned off your unit and plugged in the esp, then turned them back on. The esp code connect upon power up, but heat pump is not ready. I just plugged mine in while the heat pump was powered on, so never had this issue. I will modify my library to auto-reconnect if it does not get status from heat pump in a timely manner. This should fix that issue and also mitigate issues on power loss.
Posted:
Tue Feb 07, 2017 4:04 am
by Albertooo
I got it working!!!!!
Thanks swicagooo!!!!!!!
Regards!!!!!
Posted:
Tue Feb 07, 2017 5:11 am
by kayno
Hi guys - thought I would post over here now for the ESP8266 library, and to avoid the moderation delay on Hadley's blog!
SwiCago - initially I couldn't get things working with your code and then I tried unreality's and it worked straight up, hence me forking that version. I am not sure on all the timings - if it wasn't working for me because I missed your last commits, or if it was something else. Anyway, I am keen for us to get it all back to one library that we all contribute to, rather than 3!
I will take a look at yours again and do some diffing/merging etc to try and get some of my changes in. I agree that your sync() method is better than the two calls unreality has (but think it should be loop() as that seems to be a standard, e.g. mqtt.loop(), and others i have seen) and I'd also like to see the struct that i proposed in my fork to help with readability, remove magic numbers (array indexes), etc.
I think the best approach would be to fork your code and merge in from mine what I think would be good, and we can review?
I can add my mqtt example too.
Cheers
Kayne
