By muhammadumar6692
#85445 Hy Guys!
Hope all of you are fine. I am working on a Project of Controlling GPIOs of NodeMCU from Webpage, which works fine for me, but after that I am trying to send the GPIO State of NodeMCU Server to a Client which is in my case is WeMOS D1 Mini. I want to get GPIO State of NodeMCU on Client & from which I make suggestions to control WeMOS GPIOs. I have prepared & tested Sketches & the System is working in the way that the Client Pings the Server with a fixed Message String after a Several Time i.e., in my Case this is 2 Seconds, & when I Press NodeMCU Server Webpage Button to Turn ON LED, it takes too much time for execution & some times after so many clicks, the command executes. And at Client Side, I made suggestion while the GPIO State of Server is HIGH, then the GPIO of Client will go HIGH. At the other Side if I remove delays from Client Side then during getting Status from Server about its GPIO State, the Serial Monitor Continuously Displays the Device Checksum Configurations & Resets again & again. If there is some idea for fixing this issue
Any Help can be Appreciated.
Thanks in Advance.
Regards,
Muhammad Umar
