By gerardwr
#13123 The sketch is a working example to show the use of interrupts.
Each time the level from GPIO0 changes from HIGH to LOW the main loop (that prints the value of a variable) in interrupted and the value of the variable inverted.
The picture below shows the output from the sketch.
ESP_interrupt2.ino.zip
By alain 06640
#13464 Hello,
I think that there is something missing in your example related to led_pin. I suppose that it is an external led connected to GPIO2 ?
I commented the digitalWrite and the interrupt works fine.
Alain
By gerardwr
#13473
alain 06640 wrote:Hello,
Alain
You're absolutely right Alain.
For the example I removed some code to make the example as simple as possible.
I accidentally left a "digitalwrite" line for an external LED, and it caused a compile error.
I removed the line in the original post now, so it compiles OK.
Thanks for reporting it !
